Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
PoE on Orbi Pro
Cirvin
PoE on Orbi Pro
Can POE be used to power the SRK60, and SRS60?  The dirctions show how to mount them to the ceiling, but makes no mention of delivering power to the unit.  POE Injector maybe? or not compatible with POE to power the unit?
Model: Orbi Pro Tri-band WiFi System (SRK60) AC3000
Message 1 of 3
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: PoE on Orbi Pro
Hi Cirvin,
Welcome to our community!
Orbi Pro does not support POE. It could only be powered up by the power adapter included in the package. Yellow Port on the router is for internet not for POE.
Please refer to this installation guide.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 2 of 3
All Replies
JohnC_V
NETGEAR Moderator
Re: PoE on Orbi Pro
Hi Cirvin,
Message 2 of 3
nmhTester
NETGEAR Expert
Re: PoE on Orbi Pro
Thank you for your patience
Please check our new PoE powered Orbipro satelliate.
https://www.netgear.com/orbi-pro/src60.aspx
We promise to keep bringing innovations and new  features to both Insight manager  and standalone OrbiPros, WAC5xx series. There are more hardware choices and software features coming out in our pipeline for this segment.
Thank you for choosing Netgear SMB wireless
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 13490 views
  • 1 kudo
  • 3 in conversation
Announcements
