Orbi WiFi 7 RBE973
SXK30B3
tintino
SXK30B3
How far or how many feet cable you can used for daisy chain and i just want to make this model support this option configuration
SXK30B3
Message 1 of 5
Accepted Solutions
tintino
Re: SXK30B3
this model SXK30B3 support daisy chain functionality ?
Message 3 of 5
All Replies
CrimpOn
Guru
Re: SXK30B3
SXK30B3
328 ft. The maximum distance is a limitation of ethernet cable, not unique to what is being connected.
https://www.tripplite.com/products/ethernet-cable-types#:~:text=Ethernet%20Cable%20Length,-The%20fur...
Message 2 of 5
tintino
Re: SXK30B3
Message 3 of 5
CrimpOn
Guru
Re: SXK30B3
Page 184 of the user manual says, "yes".
https://www.downloads.netgear.com/files/GDC/SXK30/SXK30_UM_EN.pdf
Message 4 of 5
tintino
Re: SXK30B3
ok thank you, i guess 100ft cable on each satellite be ok.
Message 5 of 5
Discussion stats
  • 4 replies
  • 1006 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
