Architekt's avatar
Architekt
Apprentice
Jun 15, 2021
SXK80 AP Mode: Disable captive portal on "Guest Portal" wifi
I have wireless 1/2/3 set up working great. I would like to use the "Guest Portal" wifi as just another wireless SSID. However I cannot see any way to disable to captive portal option. There's no check box anywhere to disable it. I don't know if this is because my Orbi is in AP mode instead of router, but I would really like to have this 4th network without having to use a captive portal as it's incompatible with what I need. If this is not possible, could this be added as a feature request? Here's what my guest portal wifi page looks like, unless I'm missing something I don't see a way to disable captive portal.
  • I don't know why uploading an image doesn't seem to be working. Also I can't edit my post anymore. Let's see if attaching it as a file works...
    • schumaku's avatar
      schumaku
      Perfectly normal - in-line images are under mandatory moderation.
      The guest network is predefined by design with a captive portal, it's not a freely configurable "Wireless 4" unfortunately.
ProSupport for Business
