Orbi WiFi 7 RBE973
Reply
SXR50 tagged VLANs for SSIDs and AP mode
hiwi
Tutor
Hi,
I'm trying to setup my SXR50 in AP mode to work with a managed TP-LINK switch to have 3 SSIDs available for HOME, STAFF and GUESTS. Each of these SSIDs would have a tagged VLAN.
So:
1) I configured my vlans on my managed TP-LINK switch
2) I created VLAN profiles on my SXR50
3) I assigned my VLAN profiles to each SSIDs
4) I setted VLAN profile "1(Default)" and mode "Trunk" to SXR50 WAN port
5) I connected the SXR50 WAN port to my managed TP-LINK switch
But when a client connects to wifi, it does not receive any IP. When I disable the VLAN profiles and I sets a PVID on the port of the managed TP-LINK switch, the client have an IP.
What is the problem ?
Sorry for the question I'm a newbee.
Message 1 of 18
Accepted Solutions
hermesromeror
Apprentice
Re: SXR50 tagged VLANs for SSIDs and AP mode
Is not an Orbi requirement, its the concept of vlans. Imagine each Vlan as separate LAN with a different network range.  The benefit is that you can use a single port or switch to manage several networks.   I forgot to mention that the ports connecting the firewall to the switch and the switch to the Orbi must be configured as Trunks.
Message 13 of 18
All Replies
hermesromeror
Apprentice
I think you missed the firewall configuration. DHCP must be configured for each vlan.
Message 2 of 18
hiwi
Tutor
DHCP must be configured for each vlan ?
I configured several vlan on my tp-link switchs and it have no problem.
Message 3 of 18
hermesromeror
Apprentice
Yes, is your firewall the DHCP server?  It supports VLAN?
Message 4 of 18
hiwi
Tutor
My DHCP server is a netgate and I never configured VLAN on my netgate.
Why I need configure VLAN to use VLAN on my SSIDs ?
Message 5 of 18
hermesromeror
Apprentice
You never configured VLAN on the netgate because you were not using Vlans.  Each vlan you are creating at the Orbi are separate networks, for example: 192.168.1.x /255.255.255.0 , 192.168.2.x  /255.255.255.0, etc etc.  Each of those networks needs a DHCP server. So what you should do is to vlan tagging until the netgate and there assign the network for each VLAN.
Message 6 of 18
hiwi
Tutor
I configured Vlans on my managed switch :
Message 7 of 18
hermesromeror
Apprentice
That is correct. Is a L3 switch? the switch will create the networks and do DHCP?  If not, pass the tagging to the firewall and create the networks there.
Message 8 of 18
hiwi
Tutor
No (https://www.tp-link.com/fr/business-networking/easy-smart-switch/tl-sg105e/#specifications)
I don't understand why I must do that. My current vlans work without that. Sorry for this questions ?
Message 9 of 18
hiwi
Tutor
I want understand Thanks
Message 10 of 18
hermesromeror
Apprentice
Sorry, probably i missed something. What current Vlans and working?
Message 11 of 18
hiwi
Tutor
The orbi needs several ranges IP to retrieve the VLAN ID associated ?
Message 12 of 18
hermesromeror
Apprentice
Message 13 of 18
hiwi
Tutor
I uses VLAN ID et  PVID to separate my network. It's a bad idea ?
Message 14 of 18
hiwi
Tutor
Ok I configured my vlans on my pfsense .
I tested a vlan with a computer and I have an IP in the vlan range. It works 🙂
When I connect a computer to Orbi with ethernet, I have an IP in a vlan range. It works 🙂
When I connect a computer to Orbi with wifi, it can't get wifi 😞
An idea ?
Message 15 of 18
hiwi
Tutor
When I use the VLAN profile 1, it works
When I use another VLAN profile, it doesn't work
The Wan ethernet port of orbi have trunk mode.
Message 16 of 18
hiwi
Tutor
I resolved my problem.
I made an error in my pfsense config.
Now all works. Thank you for your help and sorry again for my novice questions.
Message 17 of 18
hermesromeror
Apprentice
glad to hear that!
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 3205 views
  • 3 kudos
  • 2 in conversation
Announcements
