nitropower
Sep 20, 2022Tutor
SXS30 + 3 satellites
Hello Everyone,
Network Been working well this year we replaced all the old Chromebook with new samsung versions and added 30 more books.
I also need to move 1 or two sats to Ethernet back haul. I want them to use the WLAN associated with LAN 3 and receive DHCP from that LAN seg. 192.168.30.x
Do I connect the sats to the Port on router that is set in VLAN Bridges settings to LAN 3 they will be daisy chained going thru a 4 port GIG switch.
Router lan port 3 setting in bridge settings --> Switch1 --> Switch2 --> to Sat 1 in new building.
|---> Switch3 - Sat 2
|--> Sat 3
I have found using the Default setting on the VLAN/Bridge setting if Hardwired Back Haul the wireless network for say wireless network 3 will no give DHCP address. for that network but if we use the wireless tied to Default net it fine no issues.
If I don't use Ethernet back haul and use the wireless back haul all the wireless network will provide the networks IP address in the ranges I chose in configurations.
Also even though it on Gig Networks sats show that they are 2.4 G Not 5G like if using the Wireless Back haul. see attached-dev.png
1 Reply
