- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgrade from Orbi Pro SRR60
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using ORBI pro with 4 sattelite. I need to upgrade to WI-FI 6 System. I need to know that and I use SRR60 with the RBK853 system. or can I combine with AP mode.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Orbi Pro will not be compatible with Orbi AX. You could setup the Orbi Pro in AP mode and have a separate SSID network. I recommend keeping the channels between each system far appart. I.e. Orbi Pro set to channel 1 on 2.4Ghz and Orbi AX to channel 11.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgrade from Orbi Pro SRR60
By this solution, Let's say I have "SSID-RBK853" and "SSID-SRK60". If I run web server connect to "SSID-RBK853". and some of client connect to "SSID-SRK60".
Some addition question.
1. Will it can communicate each other?
2. Will it get same ip class? and get fix ip from RBK853 router.
3. ORBI app, I need to seperate setting of 2 router. am I right?
I would like to buy more SRS60 satellite to make network more stable but If possible I would like to buy RBK853 instead and combine it together.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@igxer wrote:By this solution, Let's say I have "SSID-RBK853" and "SSID-SRK60". If I run web server connect to "SSID-RBK853". and some of client connect to "SSID-SRK60".
1. Will it can communicate each other? If you put the Orbi Pro into AP mode yes.
2. Will it get same ip class? and get fix ip from RBK853 router. Yes. Or you can set a manual Static IP address on the SRR router in ap mode. I recommend using 192.168.1.60. Set the default IP address pool on the RBR850 to 192.168.100 to .200. Need to keep static IP addressed devices out side of the default IP address pool on the main host router.
3. ORBI app, I need to seperate setting of 2 router. am I right? No sure about this.
I would like to buy more SRS60 satellite to make network more stable but If possible I would like to buy RBK853 instead and combine it together. Having too many RBS or too much wifi signals in one location can be problematic. Just be careful. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the helpful information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
