Orbi WiFi 7 RBE973
Reply
AX is not turning on on Orbi router
Denveronly
hi there, i turn it on in the router webmenu, the router reboots, but no changes. It is still off
webmenuwebmenu
Message 1 of 3
Denveronly
Re: AX is not turning on on Orbi router
Message 2 of 3
Guru
What broswer are you using?
Try IE11, Edge or FireFox or Opera to see if same thing happens.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 630 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
