- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX4200
- Mark as New
- Bookmark
- Subscribe
- Permalink
AX4200
Viens de brancher mon orbi 6 sur ma Freebox delta
tout fonctionne mais je ne trouve pas le debit internet tres fort .... dois je désactiver le wifi de ma free box ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX4200
Sorry and thanks for helping !
simple question for which i see different answers on the web
after having connected my orbi 6 device to my box ( free) , should i disconnect the original wifi from the box or no need ?
my operator says no need but isn't better to have netgear orbi manage the only wifi ?????
thanks a lot
laurent
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX4200
"my operator says no need but isn't better to have netgear orbi manage the only wifi ?????" Yes.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
