- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Antivirus stopped updating
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Looks like after updating firmware Antivirus stopped updating, Please find the details internet is working able to update the firmware.
Antivirus stopped udating
Model Ready NAS 424
Firmware: 6.10.5 Hostfix 1
WARNING: Your ClamAV installation is OUTDATED!
WARNING: Local version: 0.100.2 Recommended version: 0.103.4
DON'T PANIC! Read https://www.clamav.net/documents/upgrading-clamav
main.cld is up to date (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
WARNING: getpatch: Can't download daily-26338.cdiff from db.tw.clamav.net
ERROR: getpatch: Can't download daily-26338.cdiff from db.tw.clamav.net
WARNING: Incremental update failed, trying to download daily.cvd
Trying host db.tw.clamav.net (2606:4700::6810:da54)...
nonblock_connect: connect(): fd=4 errno=101: Network is unreachable
Can't connect to port 80 of host db.tw.clamav.net (IP: 2606:4700::6810:da54)
Trying host db.tw.clamav.net (2606:4700::6810:db54)...
Can't connect to port 80 of host db.tw.clamav.net (IP: 2606:4700::6810:db54)
ERROR: Can't download daily.cvd from db.tw.clamav.net
Giving up on db.tw.clamav.net...
Update failed. Your network may be down or none of the mirrors listed in /etc/clamav/freshclam.conf is working. Check https://www.clamav.net/documents/official-mirror-faq for possible reasons.
root@TDNAS:/var/lib/clamav# clear
root@TDNAS:/var/lib/clamav# freshclam
ClamAV update process started at Fri Nov 5 16:26:03 2021
WARNING: getpatch: Can't download daily-26338.cdiff from database.clamav.net
Can't connect to port 80 of host database.clamav.net (IP: 2606:4700::6810:db54)
Trying host database.clamav.net (2606:4700::6810:da54)...
Can't connect to port 80 of host database.clamav.net (IP: 2606:4700::6810:da54)
WARNING: Can't download daily.cvd from database.clamav.net
Trying again in 5 secs...
ClamAV update process started at Fri Nov 5 16:26:09 2021
Trying host database.clamav.net (2606:4700::6810:db54)...
ClamAV update process started at Fri Nov 5 16:26:14 2021
ClamAV update process started at Fri Nov 5 16:26:19 2021
ClamAV update process started at Fri Nov 5 16:26:25 2021
ERROR: getpatch: Can't download daily-26338.cdiff from database.clamav.net
ERROR: Can't download daily.cvd from database.clamav.net
Giving up on database.clamav.net...
WARNING: getpatch: Can't download daily-26338.cdiff from db.cn.clamav.net
ERROR: getpatch: Can't download daily-26338.cdiff from db.cn.clamav.net
Trying host db.cn.clamav.net (2606:4700::6810:db54)...
Can't connect to port 80 of host db.cn.clamav.net (IP: 2606:4700::6810:db54)
Trying host db.cn.clamav.net (2606:4700::6810:da54)...
Can't connect to port 80 of host db.cn.clamav.net (IP: 2606:4700::6810:da54)
ERROR: Can't download daily.cvd from db.cn.clamav.net
Giving up on db.cn.clamav.net...
ClamAV update process started at Fri Nov 5 16:26:26 2021
Thanks
Ali
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Antivirus stopped updating
You might get better helpin the readynas forum and not in the AX router forum 🙂
New ReadyNAS Users & General Discussion - NETGEAR Communities
