- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Chamberlin - MyQ tried everything RBK50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Frustrated...just spent a bit moving from my NIGHHAWK to the 'mesh' thing.
i have tried everything SHORT of RECONNECTING my old router and or extender
after spending time (so as you all dont waste your time)
I've tried it all, and some things I CANT NOT TRY..
unless im BLIND there isnt the abilty to DISABLE AM MODE (see below screen grab)
the CTS Values are all ready IDENTICAL
heres one I thought might work, (my idea)
I enabled GUEST NETWORK and renamed to the PRIOR SSID NO SECURITY...(thinking as soon as i saw all the 2.4Ghz things show up) as I automatically saw my SMART LIGHTS and other ONLY 2.4Ghz things show up, thinking i was gonna save my time to reconnected them all...
I tried the WEB URL BROWSER idea from the garage door folks setup.myqdevice.com/start.html
that didnt work...
would it be easier to return my ORBI, go back to the old?
the only thing i havent seem any good instructions on is how to make the ORBI work with one of my old AC750 extenders?...
but again i really dont feel i should I did my homework and all my other only 2.4 Ghz devices have no issue...and i aint changing out my garage door 🙂
HELP!!! Please
Im a lifelong NETGEAR person and really dont want to undo this ORBI, it really is SO MUCH better then REPEATERS all over the house
thanks in advance
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
solved my problem..yea me...
had to reconnect / reconfigure the OLD extender to get the garage to MYQ to recennect.
then sfter connecting i reconfigured MYQ to see the ORBI network, which it did, and connected to the 2.4Ghz side of the ORBI
removed the extender
all is fine...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Chamberlin - MyQ tried everything RBK50
Not sure why the PIC didnt show up..trying again
- Mark as New
- Bookmark
- Subscribe
- Permalink
all is fine...
