- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Conflicting IP address? (NETGEAR AX4200 Orbi WiFi 6 )
- Mark as New
- Bookmark
- Subscribe
- Permalink
Total layperson when it comes to networking! My Orbi (NETGEAR AX4200)
V4.6.5.14_2.0.54 |
crashes every 3-4 weeks. Even after a reset of the modem (Netgear Model # CM1000V2) and Orbi router, my hardwired devices will not work. (the wifi usually contines to work). I have to unplug all of my hard wired cables on my "16 port unmanaged Netgear GS316 switch." I reconnect them one by one and this usually fixes the problem.
I've been told i have a duplicate IP address conflict? When I go to the http://orbilogin.net site and check the IP addresses, they seem to be no duplicate IP addresses. I have approximately 20 hard wired devices (thermostats, Roku's, destop computer, etc). Any solution for this problem?
Thanks, Tom
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Conflicting IP address? (NETGEAR AX4200 Orbi WiFi 6 )
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How many wireled and wireless devices do you have all contected at one time?
Does this happen if you remove the switch from the mix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@trmoore2 wrote:Total layperson when it comes to networking! My Orbi (NETGEAR AX4200)
V4.6.5.14_2.0.54 crashes every 3-4 weeks. Even after a reset of the modem (Netgear Model # CM1000V2) and Orbi router, my hardwired devices will not work. (the wifi usually contines to work). I have to unplug all of my hard wired cables on my "16 port unmanaged Netgear GS316 switch." I reconnect them one by one and this usually fixes the problem. MyAARPMedicare
Thanks, Tom
The Netgear Orbi is technically a set of two or more wifi routers that can connect to your existing modem or router (provided by your ISP) to help blanket your home or apartment in Wi-Fi. There are also several Orbi models that include three wifi units to increase the coverage area.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually there is only 1 wifi router...there are 1 or more wifi APs in a MESH configuration that can be spred out to cover areas of the home or building.
- Mark as New
- Bookmark
- Subscribe
- Permalink
20 wired devices, but only using 2 or 3 at a time. I've replaced the switch, but the problem still occurs once in 3 or 4 weeks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 2 sattellites. They don't seem to be the problem. More or an IP problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might review this and consider updating FW:
If you do, please read the very first post in it's entirity.
