- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting Orbi direct to Sky/Openreach ONT
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm sure this has been covered before, but I was unable to find anything.
I've recently purchased an Orbi RBS353 mesh system and I want it to replace the Sky supplied router. I have FTTP and an Openrech modem. I have connected the Orbi direct to the ONT but the configuration wizard failed to find any internet.
I've seen talk of DCHP Option 61, but don't unsterstand what this means or where I can enable it. Does RBS353 support Option 61?
Any help greatfully received, thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connecting Orbi direct to Sky/Openreach ONT
https://kb.netgear.com/000062426/Which-NETGEAR-routers-support-DHCP-option-60-and-61
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
That KB article appears to be incomplete. My Orbi RBR50 definitely supports DHCP options 60 and 61.
Look on the Basic Tab, Internet menu:
Scroll down to the very bottom of the page.
Whether DHCP options are required or not is a question for the Internet Service Provides (ISP).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you see that option on your RBR750?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Both options 60 and 61 appear on the RBR750 Internet menu (after scrolling to the bottom). I have a vague memory of one of the SX models leaving off the DHCP options. i.e. SX30 and SX80 have the options, but SX50 did not. And me being surprised, "it's has been on every Netgear router since the beginning of time. Why THIS ONE MODEL doesn't have it???"
I know zero about Sky and whether they specify DHCP options (or not). For that matter, whether they require user login (or not).
There is a long post about Sky fttp and user routers here:
https://helpforum.sky.com/t5/Broadband/Third-party-router-with-FTTP/td-p/3541862
- Mark as New
- Bookmark
- Subscribe
- Permalink
Kewl, hopefully the 3 series has the same.
Thanks for checkin...
