Orbi WiFi 7 RBE973
Reply
Firmware Update Issue
Deepak_Mehta
My RBR850 is updated but my RBS are not getting updated.
Message 1 of 14
Accepted Solutions
Guru
Re: Firmware Update Issue
If you had a wired PC connected to the system there and had a remote control program like Teamviewer installed on the PC, you could update the RBS remotely. If not, you'll need to be onsite.
Message 12 of 14
All Replies
Deepak_Mehta
Message 2 of 14
Guru
Message 3 of 14
Guru
Message 4 of 14
Guru
Manyally download the RBS FW file and then log into each RBS and push the FW file to each RBS.
Message 5 of 14
Guru
Disregard my prior link. meant to post on a different post and accidentally did it on here. My bad.
Message 6 of 14
Guru
Smiley Wink
Message 7 of 14
Deepak_Mehta
For RBR i was'nt taking the update from internet, i have done it manually, but RBS i am not able to do it.
Message 8 of 14
Guru
Are you logging on to the RBS web page and sending the FW direclyt to the RBS there using there web pages? You can do this if the updating process doesn't work from the RBRs web page.
Message 9 of 14
Guru
Message 10 of 14
Deepak_Mehta
The problem is that i am sitting on a remote location, due to which i can access RBR remotely, but cant access RBS from outside.
Is there any other solution from which i can do that.
Message 11 of 14
Guru
Message 12 of 14
Deepak_Mehta
I will check out that or else will visit and do it manually.
Thanks @FURRYe38
Message 13 of 14
Guru
Smiley Wink
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2366 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
