- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware stuck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Today a new firmware showed up so I did click on the upgrade firmware, after upgrading the main router and one satellite show the latest firmware V4.6.9.11 but one shows the previous one v4.6.8.5 in the current version column and in the status it says with a link V4.6.3.16
Then I decided to download the firmware and apply it to that satellite manually, which I did and then the table shows like this
Model Name Device Name Current Firmware Version Status
Why it wants to update to an old version?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
After you loaded FW on the RBS first then RBR lastly, did you power OFF the units for 1 minute then back ON.
Just seems like the status is falsely reporting the prior FW version and hasn't fully updated yet.
Router RBR850 RBR850 V4.6.9.11 No New Firmware Available Satellite RBS850 Orbi Satellite-1 V4.6.9.11 No New Firmware Available Satellite RBS850 Orbi Satellite-2 V4.6.9.11 V4.6.3.16
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware stuck
thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware stuck
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
