- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
From U-Verse to Vyve - What to do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
With that move, what changes from the Orbi end of things? Previously to run my Orbi with U-verse I had to set it up as an access point and change another setting or two. Do I change these back now or is there a way to factory reset everything? What do I do now that I have a different Internet service provider that I believe opens up the freedoms to fully access Orbi?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: From U-Verse to Vyve - What to do?
What Orbi model system do you have?
Try Orbi with the new ISP modem?
Does the new ISP modem also have a built in router? If so then leave Orbi in AP mode.
If not, then you could change Orbi back to router mode.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One Eero router was installed to the modem. Assuming Orbi is a better product (and since I already have the router + 2 satellites), I am going to replace the Eero.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hitron
Model: CODA-45
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most CODA models are gateway modems, thus built in routers:
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
So when the installer set up the eero, he must’ve set it up as an AP? It was working great … just not reaching all ends of the house.
- Mark as New
- Bookmark
- Subscribe
- Permalink
30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
- Mark as New
- Bookmark
- Subscribe
- Permalink
What in the world?! The Orbi connects but doesn’t seem to emit wi-fi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try a full on factory reset and setup from scratch...
- Mark as New
- Bookmark
- Subscribe
- Permalink
In checking the Speedtest speeds, I noticed an oddity of sorts. The wi-fi in the upstairs playroom provided almost 600+ mbps. However, the office downstairs (and closer to the router) provided only 300 mbps. Both of the rooms in question had a satellite. Is this because of satellite placement?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy. 📡
