Orbi WiFi 7 RBE973
Reply
HELP with Orbi Mesh WiFi System
AG_2022
Hi I have the
NETGEAR Orbi Mesh WiFi System (RBK752) | WiFi 6 Mesh Router with 1 Satellite Extender |WiFi Mesh Whole Home
and my supplier is Virgin Media with a Hub 4. I thought I had followed everything to the letter, including enabling modem mode on the Hub 4 but can't get it to connect to the internet. Can I ask for the idiots guide on how I set this up please? Thanks, Amanda
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 7
Guru
Re: HELP with Orbi Mesh WiFi System
I always seem to see people having issues with the virgin hubs.
What many do is leave the virgin hub in router mode, disable its wifi, and then put the netgears IP address into the virgin hub's DMZ.
If that doesn't work, you could simple leave the virgin hub in router mode, disable its wifi, and put the netgear in access point mode.
Sadly, you do lose some features on the netgear if you do that.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
Message 2 of 7
AG_2022
Thank you. So connection wise/wires what does that look like? Between the Virgin HUB and the Orbi router.
Message 3 of 7
Guru
simply from the virgin's lan port to the orbi's wan port.
Message 4 of 7
AG_2022
So does the ethernet cable from Virgin go into Orbi or do you keep the virgin connection and then connect via ethernet between the two?
Message 5 of 7
Guru
Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 6 of 7
AG_2022
Sorry still not there with this. 😔 So I have disabled Wifi on the VirginHub and have my ethernet cable from that to Orbi and have a connection. BUT if I go the app on orbilogin.com  I am getting a ' Router Not Found Message'
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1346 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
