haysjp's avatar
haysjp
Star
Jan 27, 2023
Is anyone else having serious reliability problems since this update?
Is anyone else having serious reliability problems since this update?  I have an active support ticket open with netgear, but we've almost exhausted every configuration option.  My roaming devices disconnect from the wifi and don't come back without resetting network settings.  Many of my fixed devices cannot keep a connection.  My wired backhaul was broken after this update and I had to systematically power cycle everything a few times to get it to come back, the orbi app showed wireless even though things were wired, etc.  Even with wired backhaul restored, my devices are not keeping their connections.
I'm going to observe and capture more information over the weekend, but looking for community help in addition to netgear support.
  • The best part of this is, I got these from netgear.com in December so the refund window has already passed according to support. The model of forcing paid subscriptions for features that are free on other offerings, and not allowing returns after breaking updates is a pretty awesome customer experience.
    • haysjp's avatar
      haysjp
      Star
      I don't want to piggy back on your issue because I don't have Nest Cameras in the mix.  However, I'm running the the same system and firmware, and it's been unreliable since I got it.  The firmware update actually broke my wired backhaul and confused me for a while.  Multiple system reboots ended up getting me back to where I thought I wanted to be, but the reliability is just not there on this system.  I have an active ticket open with Netgear Support, but we've exhausted almost every configuration option available.
      My roaming devices lose wifi regularly and can't reconnect, my fixed devices that used to work fine lose their connections, etc.
      I'm going to open a similar community post to see if anyone has additional ideas after more observation this weekend.
      I can fallback to different solutions and everything works fine.  It's just the Orbis struggling sadly.
      Good Luck!
      • FURRYe38's avatar
        Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
        What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
        What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
        Is Armor, SPC, IoT and Separate 6Ghz SSID networks enabled?
        How are the RBS connected to the RBR, directly behind the RBR or is there a LAN switch in between? Brand and model of this switch please.  Using the 2.5Gb LAN Ports or 1Gb LAN ports for wired backhaul?
        Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
        Turn off and unplug modem.
        Turn on computers and rest of network.
    • haysjp's avatar
      haysjp
      Star
      Sadly, I got the system as an early Christmas 'gift' in December.  Since it was purchased from netgear.com I'm already past the return window.....I'll stick to Amazon or other from now on.
      I'm still invested in fixing it for the good of the community, but losing hope.  I'm an engineer by trade and fairly savvy with troubleshooting networking systems (doesn't mean I know everything, but I've tried and read a lot more than I wish to admit about this before opening a ticket).  I hope whatever is happening can be fixed via a firmware update, but I can't currently trust this as my primary wifi solution since my wife and I work from home almost 100% of the time.  We haven't taken a wifi outage in years.  Everything is UPS protected so we literally survive power outages as long as the ISP is up.  We haven't had an error free day since these were introduced into the house.
