Orbi WiFi 7 RBE973
Reply
Is the CBK750 compatible with the AX6000 series (RBK853)
guardtorah
Follower
I don't see a cable modem built in for the AX6000 series (RBK853), so I am wondering if the CBK750 is compatible with the AX6000 series (RBK853) if I want to replace my cable modem but have the ultra performance of the AX6000 series (RBK853).
Thanks
PS would have be nice if they had made a cable modem replacement for the AX6000 series (RBK853).
Message 1 of 3
Accepted Solutions
vkdelta
NETGEAR Expert
Re: Is the CBK750 compatible with the AX6000 series (RBK853)
If you already have RBK853, dont buy CBK750. Just get a modem to put in front (such as CM2000).
Please make sure your ISP supports CM2000 before you purchase.
Message 3 of 3
All Replies
Guru
RBK are router only "Kits". No built in modem. CBR or CBK's are Orbi systems with a built in modem.
I presume the RBS7 and 8 series from the RBK7 and 8 series kits maybe compatible with the CBR750 as this is a AX supporting system. Something to ask NG support about to get there official word on.
@vkdelta
IF you already have a RBK8 series system, I would avoid getting the CBR750 and get a NG CM1000, 1100,1200 or CM2000. The CM2000 would be best was both the RBK8 and CM2000 support 2.5Gb connection rates on there WAN ports. Mine works great with the CM2000.
Message 2 of 3
vkdelta
NETGEAR Expert
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1162 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
