- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Is there any benefit to have a wired backhaul for an Orbi Mesh system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is there any benefit to have a wired backhaul for an Orbi Mesh system?
For what it's worth, I am on Comcast and lurk on their forums, and they have specific specs for their network which are for upstream. If applicable, would also indicate you are within spec:
Upstream Power Level: +25dBmV to +54dBmV
Upstream Signal to Noise Ratio (uSNR): >31dB
Upstream Receive Power: -2dBmV to +2dBmV
- Mark as New
- Bookmark
- Subscribe
- Permalink
@donawalt Thanks for the confirmation. It's just the conflict between 'stated' tolerance limits and what truly is acceptable vs.not and I know having those upstream power levels I'm on the higher side.
@FURRYe38 correct, I just checked again on the modem logs and nothing shows. Log is empty.
Do you guys think it's worthwhile to swap out my 2-way splitter to something that is still MoCA compatible but with lesser loss? Currently my 2-way splitter is a -4.5 db for each output terminal, but I do see another splitter that I can get that is -3.5 db for each terminal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it's inexpensive to try, might be worth trying.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So to update, still with my MoCA setup, I swapped out my 2-way splitter originally having -4.5 db loss for both output terminals for another 2-way splitter that has -3.5 db loss to each terminal. The hope was that swapping the splitters would have a positive impact to lowering my upstream power levels slightly.
Looked at the cable modem signals and downstream remained the relatively the same as before, but the upstream levels actually increased! Definitely was not expecting that - I was thinking that the power would go down very slightly. Before I had power between 50 - 51.5 as the max.
I had restarted the modem and still got these stats. The modem has been up for roughly 15 hours now, no drops, no disconnects, and internet working fine as it did before. Modem log is empty.
Is this expected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If that's what the ISP has for there network and modems...
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you mean? The modem is mine (CM1000v2) and not a rental.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the signal specs are what they put forth for modems connected to there network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes- it’s like what I said above, my ISP is Comcast, and these are the specs I found on their website. The range is pretty broad, as you can see. You may have to do some hunting to find what the specs are for your ISP.
Comcast:
- Mark as New
- Bookmark
- Subscribe
- Permalink
@donawalt on the Xfinity forum, some of the 'experts' firmly disagree with those specs. They are stating that upstream power should reside around 35-50 dmbV as the optimal range and that my current levels now do not offer a buffer for fluctuation. They also mentioned that some modems have chipsets that are slightly more tolerant in higher max thresholds than other modems, which may explain why my modem hasn't rebooted or dropped connection.
I'm tempted to contact Xfinity to see if they can check out the connection from the street to my house, but on the flip side, I don't want them to inadvertently screw anything up which they have done before... The "wait and see" part has been fine so far, as I haven't experienced any internet issues yet with my MoCA setup, but not sure if I continue to wait or if it's worth it to get a tech out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"some of the 'experts' firmly disagree with those specs." - sure - everybody has an opinion. But I would also be shocked if they come out when the levels are within their own specs.
You haven't shown your modem status page (there was one image post that did not show up for me in your post earlier), are you getting lots of uncorrectable errors on a daily basis? In your log, are there a lot of CM-STATUS messages, especially 16 and 24?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since I installed the new splitter, I'm getting 51-51.5 dbmV for upstream power across the 5 bonded channels and no uncorrectables. CM log is empty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds excellent! If it was me I would just watch it - with no errors and no warnings, it's hard to imagine a concern imho.
- « Previous
- 1
- 2
- Next »
