Orbi WiFi 7 RBE973
Reply
Issues with throttling internet speed.
BlueMoon1801
Follower
Model:
AX4200 WiFi Satellite (RBS750)
I'm plugged in via ethernet with my gaming desktop. Just bought this 5 days ago and was working good the first day. Been having problems with it since then with it throttling my speed. When I restart it while it is pulsing white my speeds are back to normal. Then after it is all done restarting and returns to its amber light my speed goes back down and is inconsistent. Randomly every 30 minutes or so it will pulse white and then I will get my speed back for about 1 minute to 30 seconds then will go back to the amber light and my speed will then be throttled.
Link to the pulsing white speed test:
https://www.speedtest.net/result/11957489775
Link to the amber light speed test:
https://www.speedtest.net/result/11957494883
Any help will be appreciated, thank you 🙂
Message 1 of 3
Guru
Re: Issues with throttling internet speed.
MIght get better results posting in the Orbi AX forum for the RBK750
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
I'd also include what gateway you're using
Message 2 of 3
Guru
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Armor, AX mode on the RBR and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 645 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
