- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My router resets or loses connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the exact same router and the exact same problem. I went to L2 support and now they want me to go with Engineering support to continue figuring out what is happening. I have roughly 50 or so IOT devices (light switches, cameras, speakers...) and they just cannot connect (or some do, but most don't). And when I reboot the router, I usually cannot connect from the phones in the house. I was sent a replacement router, but it does the exact same thing. I am not sure what I am expected to do, but I will see if I need to talk with the L3 support and figure something out. I have bought another expensive router from a competitor - and it is working flawlessly. Very frustrated and running out of patience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My router resets or loses connection
What Orbi model do you have?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Are you using the IoT SSID broadcast for your IoT devices or just the main wireless SSID broadcast?
How many devices do you have connected?
Do you have the 6Ghz separate SSID broadcast enabled?
What channels are you using?
