- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware Out Today...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware Out Today...
Not yet.
New Features and Enhancements:
- Includes RIPng support for China NAL certification
- Updates the BDF table
Not sure what all this is for...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I grabbed the 3.2.16.22 downloads to add to my library. I like having "hard copies" in reserve. I'd like to get into the RBR mainpage to see if it suggests this FW. But have tried and no joy. If I can get in, I will update using what the RBR DLs. I can get to the RBSs and update them as they should be done first, but would like to still have the RBR involved as we should be able to.
My next step will be to create the circumstances where I can access the RBR and go from there. Although, the RBSs get updated first, I'd still like to do it in a "natural" manner to emulate the natural update process to see if this FW fixes any of the connectivity issues without special handling.
UPDATE:
Did a 10 second Power Cycle on the RBR, not only did it come back on line very quickly, I was able to get right in using a hardwired machine and Waterfox. The Orbi App worked also, but it asked me for the password when I have "Remember Me" turned on and in the failures it didn't it went right to the "discovery" page. Probably because it was not connecting to the RBR. So far the RBR is not showing any new FW available. So there goes organic updating. Now to update manually, RBSs then the RBR manually and as a "Dirty Update", not wiping and reinputting all settings manually. I'll do that later depending on what happens when "Joe Normal" or the RBR suggests the updates do.
(May have to post results in a separate post since there is a time expiration on editing posts.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I checked mine and nothing mentioned for updated in the UI. However I believe mine is disabled from auto upates on NGs side to due to some testing with v11.2 and NEST. So there is that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has the NAT Loopback issue (hairpinning) been sorted out with this new firmware? I'm currently running on a Netgear hot-fix firmware and would hate to disrupt my setup knowing that this is a still an issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I installed as well; so far so good; won't konw if it resolved the admin portal/app hanging issue for a few days but at least everything is back up and running ....
Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something you'll have to try out as you and maybe a few others only seem to use that feature...
@pickwit wrote:Has the NAT Loopback issue (hairpinning) been sorted out with this new firmware? I'm currently running on a Netgear hot-fix firmware and would hate to disrupt my setup knowing that this is a still an issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just about 24 hours since installing (Dirty) and all is mostly well. I have been able to get into the RBR via a hardwire and WLAN connections and the Orbi App (Android). Although the Orbi App is connecting, it keeps crashing back to the discovery/device entry page. I have tried many things to cause the crash and the only thing I can think of is it's losing its connection to the RBR since it crashes back to the "Detecting Product" page. Last I did get two enteries for the RBR, one showing the RBR850 with a Green Dot and "Connected Locally"; the other showing the RBR850 with a Red Dot and "Disconnected" with the serial number. Also I'm still getting weird results on speed tests through the app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would also post about this over in the Orbi app forum Sir Orbi.
@FarmerBob1 wrote:Just about 24 hours since installing (Dirty) and all is mostly well. I have been able to get into the RBR via a hardwire and WLAN connections and the Orbi App (Android). Although the Orbi App is connecting, it keeps crashing back to the discovery/device entry page. I have tried many things to cause the crash and the only thing I can think of is it's losing its connection to the RBR since it crashes back to the "Detecting Product" page. Last I did get two enteries for the RBR, one showing the RBR850 with a Green Dot and "Connected Locally"; the other showing the RBR850 with a Red Dot and "Disconnected" with the serial number. Also I'm still getting weird results on speed tests through the app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can confirm that NAT loopback works perfectly with this new firmware.
I've been running with it for 2 days now and so far all round no issues to report.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
FYI; it took longer than in the past with the new firmware but sometime last night the admin portal and apps stopped responding just as before. Internet access in general to my devices remains ok. So, at least in my case, the exact same issue surfaced as before. I will also update Netgear.
Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
What thsi seen on diffferent PCs and different broswers not be able to access the routers web page?
Had the RBR been factory reset since last update?
@bikerapn wrote:Hi All,
Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi - I factory reset before the update but I did not do so afterward. I can do that later today after work finishes and then start my timer from there. I'll report back in the next several day ....
Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey,
I just upgraded to this today and my first reaction is that it has halved the speed that my devices have when connected to the satellites. I previously got around 400Mbps at the end point, but it's dropped to 200 or so now in multiple tests.
Mind you I am using Xfinity with around 1150Mbps download and 40Mbps upload.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i can confirm this as well. I have the same plan speeds from my provider as this user and can now only get 100 down from a wired connection to the RBR850. Will downgrade to fw 3.2.16.6 in a bit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
@doucheopotamous wrote:i can confirm this as well. I have the same plan speeds from my provider as this user and can now only get 100 down from a wired connection to the RBR850. Will downgrade to fw 3.2.16.6 in a bit.
