- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
New - RBR750 / RBS750 Firmware Version 7.2.6.21 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RBR750 / RBS750 Firmware Version 7.2.6.21 Released
Well may have worked in v4 FW however possible your config that way and it working was an unintended configuration. The path configuration has been the correct and support path configuration for all orbi systems, router or AP mode and ethernet connected RBS, since I started using Orbi and learning all about them. Aside some problematic FW versions and use of managed switches and issues there, ethernet connected RBS have always worked in this configuration. With out any VLAN or use of the LAN port with a host router configs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ducs4rs wrote:
Why do you need a dedicated connection from the RBR to the Opnsense router? Not sure how I would set this up.
The picture (thanks for posting that!) appears to show a white cable going into the switch. (is that from the OpenSense router?) Perhaps connect the white cable to the Orbi @wan port and run the orange (red?) cable from a router LAN port to the switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I got it sorted out thanks to this post. I created a backhaul vlan on a managed switch. The WAN port is VLAN'd to my home network to reach the Opnsense router. I created an isolated VLAN for the backhaul network and connected the RBR, RBS's LAN ports. It all works like a charm. Thanks for all the pointers and discussion. Sorry it took so long.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like your managed switches, when used in this kind of configuration, seem to see this VLAN to make the backhaul work. Glad you got it working. Use of non managed switches would not need any kind of VLAN config.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
the reason for managed switches is Ethernet ports. The locations of the RBR and RBS' only have one drop. The RBS' only need one, but the RBR needs two. Using managed VLAN capable switches over comes this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI, new FW is available:
Good Luck.
- « Previous
- Next »
