Orbi WiFi 7 RBE973
Reply
ORBI AX6000 Fast download, Slow upload
btx_tx
Model: RBR850 and 2x RBS850
Firmware: V4.6.3.16_2.0.51
Speed Test from Orbi Admin Panel: 932.7Mbps Download; 939.48Mbps Upload
Speed Test from Macbook Air M1 (wireless): 738Mbps Download; 163Mbps Upload
For some reason my upload speeds over WiFi are not at all close to my download speed. Any one else having a slow upload speed?
Any thoughts or suggestions are welcomed!
Message 1 of 10
Guru
Re: ORBI AX6000 Fast download, Slow upload
What connect rate speed is the mac book air connecting at with the RBR. I'd turn OFF the RBS temporarily to ensure the mac book connects to the RBR. Use the Opt key + Right Click on the wifi icon on the top tool bar on OSX to see additional information and the connection rate.
Message 2 of 10
btx_tx
TX Rate is 864Mbps
Message 3 of 10
Guru
You should see near 1300Mbps or over. What the highest connection rate supported by Apple for this Mac Book? My 2018 supports 1300Mpbs. I usually see around 700Mpbs speed results.
Message 4 of 10
btx_tx
Interesting...my download speeds are great (700+mbps) but upload cannot seem to break 200mbps.
I checked my phones as well, 600+mbps download, ~150mbps upload.
I'm not sure what else to try...maybe it is a bug in the firmware?
Message 5 of 10
Guru
Are wired speeds good on the up?
Is WMM enabled under Under Advanced Tab/Advanced Settings/Wireless Settings
What are the current CTS values?
Message 6 of 10
btx_tx
Yes, WMM is enabled and on wired my upload is 800+mbps.
CTS 64
Attached a couple screen shots.
Screen Shot 2021-10-05 at 10.46.06 AM.pngScreen Shot 2021-10-05 at 10.47.58 AM.png
Message 7 of 10
Guru
What OSX version are you using on the Mac Book?
You can try setting CTS to 2307 and see.
Try disabling AX mode on the RBR and test...
Message 8 of 10
btx_tx
macOS 11.6
CTS change did not make much of a difference.
The M1 Mac has AX capability.
Message 9 of 10
Guru
Would be a good test to see if there is any differences between AX mode enabled or disabled...
with AX mode, your connection rates should be at least 1300Mpbs...however check Apples web site or support pages to see what they support for connection rates on that model book for AX and AC modes. AC mode you should see 1300Mpbs at least at the RBR.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1918 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
