× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
Orbi 6 blocks silicondust Homertun prime cable tuner
vmaher
One of my primary uses for my network is to distribute cable channels using the HDhomerun prime box. But the Orbi mostly blocks media center and firesticks from using it. Can connect using the HDhomerun app directly on the computer but not on the firesticks or media center. Sometimes it works but mostly it doesn't. Doesn't make a difference if it's connected hard wire or not. Seems Orbi is blocking something. Coming from a Google Nest system which worked fine except it was slow. The Orbi is fast but erratic.
Rebooting didn't help. Can use the HDhomerun if connected directly to an external hub and using my TPlink access points. If I plug the HDhomerun directly in the Orbi it gets blocked so even the TPlink access can't get to the box.
Using the web interface it looks no services are being blocked. It looked like it ran fine for a day after I installed from the Web interface. When I installed the phone app it activated Armor even though I thought I was careful not to get it. Turned it off but I see some people thinks it turns off comletely. Don't know if that's related.
Any suggestions? Otherwise I guess I have to send it back.
Message 1 of 5
Guru
Re: Orbi 6 blocks silicondust Homertun prime cable tuner
What devices are connected to the RBR? I presume wire configurations are as follows?
ISP Modem>RBR<>WIred devices behind the RBR?
What happens if you set up the DMZ on the RBR for this device?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 5
vmaher
It's connected to an Arris surfboard SB6141.
Orbi firmware V3.2.16.6_1.4.4
external hub plugged into Orbi.
HDhomerun TPlink and HDhomerun connected to hub.
PC sometimes connected to Orbi Sometimes to Orbi direct.
PC when connected to hub Media center works fine. Connected to Orbi no go. Direct  HDhomerun app works.
Firesticks connected Orbi wireless mostly no go. Sometimes works. Firesticks connect to TPLink AP work fine.
Plug HDhomerun directly into Oribi media center and firesticks don't work. Orbi seems to be blocking something.
Set the HDhomerun as DMZ - no change.
Disable port scan - no change
Disable IGMP proxing - no change
Diable NAT  filtering - no change
Set the above separately and combined - no change
No services blocked. No access control.
Not enough granualrity in the Orbi interface to tweak much else.
Quoted
Message 3 of 5
Guru
Modem wouldn't be blocking anything. I would think the DMZ would help on this. Did you reboot the RBR and modem after setting up the DMZ?
Only other trial to do would be to put the prior router back online after the modem, disable ALL wifi radios on that router. THen configure the RBR for AP mode and see what happens.
Seems there maybe a FW issue with this certain media device. Something to contact NG support about and see. If not, you may need to find something different.
Message 4 of 5
Guru
What tp-link AP do you have?
I've had issues with HDhomerun when devices aren't running properly in Ap mode or are having dhcp conflicts.
If you take the Tp-link AP out of the equation and reboot your network, how does it work?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 458 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
