Orbi WiFi 7 RBE973
Reply
Orbi AX4200 Satellite with AX5400 router?
Oksell
Follower
I have 2 Orbi AX4200 satellites (RBS752).
Can I buy the Orbi AX5400 (RBK763s - with a router and 2 satellites) and also use my existing satellites for a ”larger” mesh network?
So the short question is, are these two different Orbi-versions compatible and able to create a mesh network?
Message 1 of 2
CrimpOn
Guru
Re: Orbi AX4200 Satellite with AX5400 router?
Netgear published this table of which satellites are compatible with which routers:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible?article=000065169
The table indicates that the 750 satellites are not compatible with the 760 router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1511 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
