- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK353 connection to Dell Latitude E7440
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have recently added the Orbi RBK353 system and all good apart from one thing, I have an old Dell Latitude E7440 laptop which can't see the Wifi, I have read that if I turn off the AX then all would work apart from loosing the Wifi 6 part of the system. However when I try to switch the AX part off through the router if says that it can't because the WPS is in use, try later. Up to now having tried many times I keep getting the same response any suggestions.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just select the "Accept Solution for the post that you mentioned that you got it working. 😉
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK353 connection to Dell Latitude E7440
Instead of crippling your system, why not work at fixing the laptop?
What wireless chipset is in it and what driver is it running?
Some laptops you can upgrade the wireless card in them. That might be worth checking into.
Or buying a cheap usb wireless adapter to connect to it.
I'd go that route over decreasing the performance of your system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for the response I have just uploaded updated software for the laptop wifi card and all is working ok now thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
