- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK852 Disconnecting Everyday
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently every early morning around 0600 the Orbi loses internet connection. I am running Century Link Fiber 1GBPS running from a ONT to the Orbi.
Rebooting the Orbi works and then the internet connects again, however this is cumbersome and also annoying. My cameras disconnect and won’t record during this time, anyone had this before and or know of a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK852 Disconnecting Everyday
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi is running 4.6.8.2
I have done all the other steps as well
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the front LED on the RBR turn PINK when this happens?
What is the CAT# lan cable between the ONT and RBR? CAT6 is recommended...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you power OFF the ONT for 30 seconds then back ON, leave the RBR left ON during the ONT power cycle?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the RBR comes back to ready with the ONT power cycled and not having to power cycle the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok is the RBR using mostly default settings after you set it up from scratch?
Armor, SPC or Traffic meter should be disabled.
You can see if enabling IPv6 changes anything however It may not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Wondering if this is playing a roll as well.
Keep an eye on the router IP address/Debug.htm page and the system uptime section. Make a note of this now.
Take note if any front LED behaviors seen when you notice the RBR looses connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR Ip address/debug.htm in a web page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you checked the UpTime seen on the debug.htm page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, lets go from here. Make sure you have the following enabled on the debug page please:
