- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR850 have internet but no wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
So my orbi RBR850 have internet and all. All my devices that are pluged in with ethernet cabel have internet. But all phones and tables keeps loosing connection to wifi. All my google, mill and other smart house devices are connected to wifi. Is it my 5Ghz that is the problem or what? In the app it says that the RBR is connected locally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR850 have internet but no wifi
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
