Orbi WiFi 7 RBE973
Reply
Orbi RBS350 leuchtet sehr oft blau, blinkt sehr oft weiß, am Tag und in der Nacht.
Das nervt mega.
Was kann ich tun, um das Problem zu stoppen?
Message 1 of 6
Guru
Re: Orbi RBS350 leuchtet sehr oft blau, blinkt sehr oft weiß, am Tag und in der Nacht.
Englisch Bitte
Das nervt mega.
Message 2 of 6
Hi,
my rbs350 satelite is ocassionally blinking white and then it is illuminated in blue.
This occurs in the night and wakes me up, during daytime and overall it occurs after a certain amount of time.
I just want to figure out, whethere or my network has been corrupted by some kind of botnetwork.
Message 3 of 6
Guru
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Message 4 of 6
Hi,
  • the Orbi RBR350 is configured as the router
  • there is the Vodafone Wifi router
    Arris Touchstone TG3442DE
     currently operating as a modem only.
  • My Home is about 70sqm
  • The distance from Orbi RBR350 to Satelite in my sleeping room is less than 30 feet
  • Yes, a 1 minute power off has been done with Orbi system and ISP modem. I will do it again.
Message 5 of 6
Guru
Can you move the RBS a bit farther away, say 35 feet?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Also might remove the RBS from the RBRs web page. Then factory reset the RBS by pressing the reset button for 15 seconds then release. Then resync the RBS to the RBR.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 854 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
