Orbi WiFi 7 RBE973
Reply
Orbi RBS760
TeresaA0627
Follower
Orbi RBS760
I have purchased an Add-on Satellite for my RBS760 Tri-band Mesh Wifi System.  It only came with US & EU power adaptor and I need the plug for Australia.  Can I purchase a compatible power adaptor because i don't want to have to send back the whole thing.
Message 1 of 2
Accepted Solutions
CrimpOn
Guru
Re: Orbi RBS760
Amazon carries power adapters compatible with most Orbi units.  Is there Amazon in Australia?
The key is the output must be 12V, 2.5 amp with the correct size plug.
Australia is a 220-240v @ 50Hz standard. Most of Europe is also 220v.  If the power adapter shipped with the unit says it is compatible with 220-240v, there is probably a travel adapter that will allow the existing adapter to plug into your outlets.
Message 2 of 2
All Replies
CrimpOn
Guru
Re: Orbi RBS760
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 771 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
