Orbi WiFi 7 RBE973
Reply
Orbi ax drops all 2.4 connection every 5 to 7 days
sutset
Guide
All my 2.4 connections both router and satellite drop every 5 to 7 days. A reboot always brings them back. Anyone else having this issue? This has been going on since latest software was installed.
Message 1 of 7
RyoWong
Re: Orbi ax drops all 2.4 connection every 5 to 7 days
Orbi ax drops all 2.4 connection every 5 to 7 days x 2
Message 2 of 7
KMDonlon
Luminary
Yes, seems to drop my Trane XL824 thermostat every 4 days or so. Thought it was just me.
Message 3 of 7
Forevermore
It is happening to me as well. Power cycling the satellite is the only thing that seems to resolve it, but only temporarily. In about a week or less it's dead again and have to recycle it again. It's getting very annoying. Never had any issues like this with my old Orbi.
Message 4 of 7
sutset
Guide
So support told me for 2.4 to always use channel 11. So I changed it from auto to 11 and mine has dropped again. But it has only been 4 days or so. A new software was released today support for multi satellites and bunch of bug fixes. I notice that my devices have stronger signals after upgrade.
Message 5 of 7
FarmerBob1
Luminary
What version was the new release?
Message 6 of 7
Guru
 IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1454 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
