Orbi WiFi 7 RBE973
Reply
Orbi
Paheve
Guide
Orbi
Hi all,
My question is about the ORBI RBS850
First of all, why is the Orbi 850 set not available in the selection list of this community when creating a question like this?
the main question is, there is no parental control available for this type of ORBI (RBR850) solution. Is this temporary or is this function completely not coming onto this system?
has anyone maybe another solution to make internet saver for childeren who are connected?
to be honest, I thought that Parental control was default available on all ORBI sets...
Many thanks for any advice.
Message 1 of 4
Guru
Re: Orbi
Don't know. Just a forum seletion that NG hasn't put in the forum list.
Circle is supported on Orbi AC however has not come to Orbi AX as of yet. A forum moderator posted not too long ago that they were working on Orbi AX support for Circle. No dates given on when that will happen.
If your wanting more information regarding this, please post in the Orbi Circle forum or make contact with NG support.
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck
Message 2 of 4
Paheve
Guide
Re: Orbi
Thanks for your response.
i will check te link you send en hope that This feature is available fast.
Message 3 of 4
Guru
Re: Orbi
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 980 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
