- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RB850 Fast Roaming
- Mark as New
- Bookmark
- Subscribe
- Permalink
RB850 Fast Roaming
My new Orbi RBK852 is now almost working except a MacBook Pro that continuously drops the connection (and I have to turn wifi off/on on the MacBook).
Community postings have suggested I turn off Fast Roaming.
The orbilogin.com interface does not show the Fast Roaming setting. How do I turn it off?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RB850 Fast Roaming
Fast Roaming is automatic on Orbi AX. No user configuration.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also what is the model of the mac device and OS loaded on it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your follow-up questions. We have actually discussed my Orbi issues in another thread.
My house isn't that big, about 3600 s.f. but it is spread out, so had some dead zones. The Orbi with Satellite provides excellent covereage (but I've unplugged the Satellite due to the Macbook issues - it drops the connection less often when the Satellite is not plugged in; it would switch between RBR and RBS even then when the RBS was only 6 feet away).
The Orbi RBR850 firmware has been ugraded to 3.2.16.6 (I have only recentrly purchased the Orbi router).
The Shaw (ISP) modem is Hitron CGNM-2250 and is in Bridge mode.
I think the solution probably lies in fiddling with the MacBook, as the other 14 devices are fine now. The Macbook was recently upgraded to the latest OS (Big Sur). The Macbook model is MPXQ2LL/A (13.3") and was purchased August 2017.
I have a case open with Netgear, but they just want to keep re-installing, resetting and reloading things ("step 1" in their "manual").
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear, your not the only one seeing this:
https://community.netgear.com/t5/Orbi-AX/RBS850-device-disconnects/m-p/1985255/highlight/true#M8029
You can post about this here as well if you wish.
Thought seems that recenly I'm not seeing this in the past couple of weeks. Mac Book Pro for me in the living room has been keeping connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try updatig to v22:
https://community.netgear.com/t5/Orbi-AX/New-Firmware-Out-Today/m-p/2005684/highlight/true#M9268
Nothing on the Mac that can be adjusted...
