Orbi WiFi 7 RBE973
Reply
RBK960 upgrade firmware issues
yili_zhao
Follower
After upgraded the firmware on RBRE 960 from V6.0.3.50 to V6.0.3.68, I can't access the website. After factory defaut reset, I can ping to 192.168.1.1 but can't access the website. Any idea?
Thanks,
Yili
Message 1 of 3
Re: RBK960 upgrade firmware issues
While many issues are generic and will apply to most routers, in this case you are asking about firmware. And that depends on the model number.
The RBRE960 is a fancy Orbi device rather than one of the Nighthawk Routers with WiFi 6 (AX) and WiFi 6E (AXE) devices covered here.
You might get more informed responses over in the section where they cover your hardware:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
Message 2 of 3
Guru
What browser are you using to access the RBRs web page? Try MS Edge, Firefox or Opera.
Be sure your connected with the RBR with a LAN cable to test.
Try a different PC or laptop.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 740 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
