- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR 750 gives message of can't connect to this network
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have a RBR 750 with 2 satellites. I have recently switched jobs and received a new HP Z Book. I can connect to our ATT&T wifi with the new computer with no issues, but when I attempt to connect to our ORBI I get the message "can't connect to this network". All of our other devices connect fine, and both satellites are connected to the base, and the base is connected to the internet. My office is upstairs along with one of the satellites. I have tried being in close proximity to the router and still get the same message. Everything is up to date according to the app as well.
Thanks for your help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR 750 gives message of can't connect to this network
HP Z Books run Windows. What does the Windows Network Troubleshooter say about this?
It is not clear (to me) whether this message:
- This message comes from the router, "I am rejecting your attempt to connect", or
- This message is reported by Windows.
Can you attach a screen shot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was just now able to connect, I think it had to do with something in Cisco. As soon as I entered the pw there it linked right in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
House is about 3900 sqft. The 1st satellite i sin the master bedroom roughly 40+ feet away, the second satellite is upstairs at probably 60+ feet away.
I believe it may have been a Cisco issue of not logging on through that program on my computer. As soon as I did that I could get in. It was kinda weird as I've always been able to login through the available networks in settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok sounds like you got it fixed. Keep that in mind.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
