- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR350 — Orbi AX1800 loosing wifi connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having trouble with the Wi-Fi system at home. Especially the satellites. The equipment I´ve got is a Orbi RBR350 router and two satellites (RBS350).
The satellites are connected with the router with a ethernet cable so they should be securely connected to the internet at all time. However, things connected to the satellites through a Wi-Fi connection keep loosing internet connection from time to time. When it happens I reset all of the equipment: modem, router and satellites. This fixes the problem so there must be something wrong with the settings.
Anyone experiencing something similar? any suggestions regarding settings?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR350 — Orbi AX1800 loosing wifi connection
What modem/gateway is it connected to?
What firmware is on the router and on the satellites?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a optic fiber box from my ISP (from Nokia)
Router and satellites have V4.4.1.29 (the newest none)
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My home is 2500 sqft in one floor. Built of concrete. The router and the two satellites are hardwired together. The distance is probably 30-40ft from each other ( but this should not matter since they are hardwired together? )
The channel settings:
And this only happens to the wifi part. I never experience problems with things I have hardwired.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, distance matters wireless or wire connected.
Building materials made of concrete will also cause problems.
What CAT# LAN cable are you using to connect the RBS to the RBR? CAT6 is recommended.
Are the RBS directly connected to the back of the RBR or is there a LAN Patch panel or LAN Switch in between?
Do all wireless devices loose the connection?
Try setting manual channel 1, 6 or 11 on 2.4Ghz.
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello @birkitre,
Welcome to the NETGEAR Community!
I understand that you are having interim network disconnects with your Orbi mesh system. I noticed in the post above you stated that the devices are connecting and dropping from your network. This can be due to having too many wireless signals in one area. To test this please disconnect one of the satellites from your network and then check for network stability. If there is no change, ensure that UPnp is enabled on your RBR350.
To enable UPnP to navigate to your Orbi admin page then Select ADVANCED > Advanced Setup > UPnP > Check " Turn UPnP on" > APPLY.
Please visit the link below for the optimal satellite and router configuration for your home:
Where should I place my Orbi satellite? | Answer | NETGEAR Support
Best,
Kevin
Community Team
