- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 - Control Panel not Displaying properly and takes a long time to load
- Mark as New
- Bookmark
- Subscribe
- Permalink
For some strange reason, the control panel takes a long time to load and then when it does it is all garbled. Almost like viewing a webpage where the CSS didn't load. While it is loading the titlebar shows NETGEAR Router WNDXXXXX and not RBR750 until it finally loads.
Firmware Version : V4.6.5.14_2.0.54
Screen shots
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 - Control Panel not Displaying properly and takes a long time to load
have you tried a different browser?
Try firefox/edge or even a different pc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried Chrome and Edge on the same desktop with the same results. Different computer, the page render is better but clicking on links doesn't load anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple other things I have thought of. It is connected directly to the ONT with a static IP address. Not sure if it matters.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you access these pages if you disconnect the RBR from the ONT?
Be sure to clear out all browser caches before entering into the RBRs web page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disonnecting from the ONT and the control panel loads correctly and is responsive. Hmmm, trying tp get rid of the terrible ISP hardware, as it is terrible to manage and underpowered. Also have a terrible double NAT situation as they don't allow bridging or pass throughs. I tried putting the ORBI in its DMZ or making the ORBI an AP but that resulted in their hardware crashing every night. Ugh, was hoping going directly to the ONT would alleviate these issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If their setup allows a DMZ, it isnt just an ONT.
What ONT/gateway is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, the ONT is an Adtran Total Access 362. From there it is running to a sr400ac router. It is there that I added the orbi to the DMZ which would cause the sr400ac to crash every 24-36 hours requiring a factory reset. They have locked the sr400ac down from what I can tell which is I why I was trying to bypass it. The ORBI works when connected to the ONT just fine, I just can't access the control panel to make any changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried update FW yet?
Can you access the web page if you disconnect the RBR from the ONT?
A factory reset maybe needed...
- Mark as New
- Bookmark
- Subscribe
- Permalink
why not just direct connect to the ont then and not through the sr400ac?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upgrading the FW seemed to do the trick. Thanks so much!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
