- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 Guest Network Wi-Fi no internet connectivity but Wi-Fi works on home network
- Mark as New
- Bookmark
- Subscribe
- Permalink
This problem started when I upgraded my Xfinity modem to the XB6 model and at the same time upgraded to the newest firmware for the RBR750 and satellites (2). The WiFi works fine on the home/main network for the RBR750. The Guest Network WiFi can be connected to, but has no internet connectivity when I connect with my iPad or phone. . What is interesting is that my Ring Cameras (6) and Tesla Powerwall App all use the Guest Network WiFi and they are all connected and working. Any ideas why the Guest WiFi has no connectivity with an iPad. but is working for other devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 Guest Network Wi-Fi no internet connectivity but Wi-Fi works on home network
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please humor me and look at the Orbi web interface, Advanced Tab, Security, Access Control. This is on page 40 of the user manual:
https://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdf
Which option is selected:
Apple and Android introduced a feature in newer versions of their software which is designed to prevent "Big Brother" from tracking phones and tablet as their hardware MAC address connects to various WiFi access points. When this feature is enabled, an iPad will appear to be a "new" device and the Orbi will reject it when the access fule is "Block all new devices."
