Orbi WiFi 7 RBE973
Reply
RBR750 Mesh network
George56
RBR750 Mesh network
I have an RBR750 mesh network with 2 satellites. They have worked well for over a year. The router is in my basement, one satellite is one flight up on the main level and the 2nd satellite is 2 stories up on the top level of the house. All of a sudden the satellites are no longer communicating with the router. They are flashing white and pink and sometimes blue. I have brought both of them into the same room with the router and reset them and attempted to sync them. In the same room all lights go out but when I put them in the other rooms - no success!
I would appreciate any advice to help get them back on line. I have no issues with the router.
Thanks.
Message 1 of 3
George56
Re: RBR750 Mesh network
Thanks Alex. I am not very technical. What specifically do you mean by power cycling?
Message 2 of 3
Guru
Ignore the poster above. He's got spam links in the profile.
1. what firmware is on the router and satellites?
2. what modem/gateway are they connected to
3. how big is the home?
4. what are the walls/floors made of? (certain materials block wifi better than others)
5. They've never had syncing issues before?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 128 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
