- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for my naive question: the automatic installation fails on my Orbi, so I decided to install it manually.
The instructions (https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co... )
says that I have to upload a .img file, but the zip file contains only a .chk file.
How should I do?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
the instructions say it can be a .img or .chk file.
It works well manually update. Use the .chk file.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will try to do so.
For information, the instructions says that you can use either .chk or .img for the satellites, but that only mentions .img for the router, hence my confusion.
Thank you for you help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should work fine.
So long as you're using the RBR file.
