- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 losing connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have annoying problem with this system the coverage itself in the house is good (router plus 2 satellites) it's attached to a tplink 4g modem via cable but randomly its gets disconnected the router turn lights to purple and after some time it's reconnecting again. Is there something that can be done?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 losing connection
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Disable AX mode on the RBR for both radios. Under Basic Tab/Wireless Settings.
Set CTS values to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Apply settings and reboot. I would do one full power OFF of the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
BTW, while the satellites are doing their multiple reboots, everything in the house reconnects to the router. It takes a few hours for the devices to get redistributed back out to the satellites.
