- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 / RBS850 Hard-Wiring Question
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi!
I have an RBR850/RBS850 system with the router and two satellites. I'm planning to add a few satellites because these system isn't big enough. I have an old house with a lot of plaster walls and fireplaces and the signal just doesn't distribute evenly.
I've had a lot of luck hardwiring the router and satellites to each other. As I grow the system, I'm wondering whether I can place an ethernet switch between the router and the satellites, such that the router and satellites all separately plug into the switch. This would allow for a more easier wiring scheme, with the satellites spread around the house.
Thanks very much!
Adam
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 / RBS850 Hard-Wiring Question
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Between the RBR and RBS if you ethernet connect the RBS to the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can run through a switch.
