Orbi WiFi 7 RBE973
Reply
RBR850 and issue with combinated wifi/wired backhaul
TheStigh
Tutor
Hi all,
Just installed a new 850 kit w/1 * RBR850 and 2 * RBS 850's.
RBR are connected to the Cisco Gb switch
RBS #1 are connected to the Cisco Gb switch
RBS #2 are with wireless only placed on 2.nd floor strictly above RBS #1.
RBS #2 would not expect to "see" (or be VERY poor) the WiFi of RBR.
Note: with RBS #2 powered off, I have 3 of 5 lines coverage on my phone in the 2.nd floor.
My question 1:
Should RBS #2 wirelessly get its backhaul via WiFi from RBS #1 ?
My Question 2:
Are this allowed and will work as a wired backhaul for both RBS?
Message 1 of 6
Guru
Re: RBR850 and issue with combinated wifi/wired backhaul
1. the RBS have their own internal algorithm that determines which to connect to. Because going through a satellite might add latency and slow a satellite down a little bit, even though its further, the RBS might be connecting to the RBR. I don't know what their internal algorithm is. I just know sometimes they connect it unexpected ways
2. you can daisy chain the satellites how you pictured.
Message 2 of 6
TheStigh
Tutor
Hi plemans,
Thank you for your quick reply.
Are you saying that we CAN expect issues where RBS #2 only connects wirelessly to RBS #1?
Our testing last night was working, suddenly stopped for a while, then re-connected.
/Stigh
Message 3 of 6
Guru
Tough to know. It can switch between the 2 as needed based on its own algorithm.
It might work perfectly fine.
Message 4 of 6
TheStigh
Tutor
Thanks again 🙂
Already we have had issues.
Disconnected the RBS #2 now and will try to use only RBS #1 from the floor above.
If that become stable, my 'kind-of' conclusion will be that we should use a cable from RBS #1 -> RBS #2.
I'll keep you updated!
Message 5 of 6
Guru
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 446 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
