Orbi WiFi 7 RBE973
Reply
Rbk753s want satellites to connect to router only
QP70325
Currently have the satellites connecting o each other (daisy chain) but i want them to connect to router only.  Currently have wifi 6 RBR750 and 3 satellites (RBS750) thst keep connecting to each other.  When they do i have a significant loss in speed.  These new version don't have the Daisy Chain enable option.  Any advice on how to make the satellites connect always to the router?
Message 1 of 5
Guru
Re: Rbk753s want satellites to connect to router only
Message 2 of 5
Guru
I
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Placement is key here since Daisy Chain is Automatic. So you'll want to be sure to place the RBS out in a Star or Spoke formation out from the RBR, not out in a line from from the RBR.
Message 3 of 5
QP70325
House is 5000 SQFt
satellites are 30-40 feet away.
Cable Modem is an Arris.  Model - TG2492LG-LIB
Message 4 of 5
Guru
What mode is the Arris modem working in? This has a built in router I beleive. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 438 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
