Orbi WiFi 7 RBE973
Reply
Rbk853 satellite 2.4ghz
Superpapu
Hi, I have the rkb853.
I detect that all the devices are connected to the main router (2,4 and 5ghz) and none to the satellites even if the device is close to the satellite.
The satellites has 2.4ghz band?
what can I do to force the connections to the satellites in order to increase the signal? In both signals
thanks
Message 1 of 9
Guru
Re: Rbk853 satellite 2.4ghz
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
is up to client devices to pick and choose where they connect too.
You can try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 9
Superpapu
Hi
4.6.3.16_2.0.51
the router is connected directly to the ont. the provider is Movistar (Spain). In general the wifi is perfect, it just the devices don't connect to the satellites
is a 860 sq flat in 1 level.
the distance is 150 sq with the first one and 300 sq with the second
you said to disable the "wifi" in the Orbi app in the devices that I want in order see if that would solve the problem
Message 3 of 9
Guru
860 sq Feet or Meters?
"you said to disable the "wifi" in the Orbi app in the devices that I want in order see if that would solve the problem" No this is not what I said. >You can try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings < this is done thru the RBR web page using a web browser.
Message 4 of 9
Superpapu
the house is 100m2 and the distance with the first satellite is 15m and with the second 25m.
Message 5 of 9
Superpapu
Here you can see all the devices to the main router and none to the satellites
Message 6 of 9
Guru
What happens  if you turn down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings < this is done thru the RBR web page using a web browser.
Message 7 of 9
Superpapu
I restart the system and now the devices are
Connected to the satellites except some of them with the weak signal. Is posible to “move” to force to the satellites ??
Message 8 of 9
Guru
No.
What happens if you disable AX mode on the RBR for the 2.4Ghz radio? Under Basic Tab/Wireless. Remove the check mark next to 2.4Ghz under AX mode. Apply the setting.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 924 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
