- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Unable to connect at 6 GHz to the Orbi RBRE960
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any resolution to this? I have a Dell XPS 15 9530 w/ Intel AX211 6E card and Orbi RBK963 (router + 2 sats).
Orbi settings are identical to the author's settings in first post.
AX211 settings are
- 6 GHz Preferred Band
- Ultra High Band (6 GHz) - Enabled
- All other AX settings enabled
Laptop is about 10 feet from the router. Using Windows Network & Internet, I'm seeing that the WiFi adapter is 100% on 5 GHz, never on 6 GHz. Double checked that all drivers - including WLAN adapter - are fully up to date. Same for the Orbi. Not sure what else to do...
This is a corporate laptop, but I have access to all areas of the machine.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
On laptop, I skipped Dell’s update and went straight to Intel, whose driver was much newer.
Both devices can now reach the limit of my WWAN (1Gbps).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you enable the separate 6Ghz SSID and connect to this network?
What FW version is loaded on the RBR and RBS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dell's web site appears to indicate that Dell 'recommends' Windows 11 for this product:
https://www.dell.com/en-us/shop/dell-laptops/xps-15-laptop/spd/xps-15-9530-laptop
There are Control Panel network settings that determine which WiFi frequencies the card can use. Perhaps it would be worth a few seconds double checking that 6GHz is enabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any information you could share on how you got the XPS 15 to connect to the 6ghz would be appreciated. I have the latest drivers from Intel and have tried everything but the XPS 15 doesn't see 6ghz. My Iphone sees the 6ghz fine but I read it has been disabled on the XPS by dell by a bios flag. I would love to get the 6ghz working as my 5ghz is congested in my location.
Thanks in advance
