Orbi WiFi 7 RBE973
Reply
Unable to cast via RBS750
SKEN57
I have recently switched over to an RBR750/RBS750 wifi 6 network. Previously had no issues casting to Chromecast or to Samsung TV. Now can't cast to either via the satelittes but can with just the router neable. I have tried all previous suggestions and getting nowhere fast.
Both are connected and can see that, the TV for example can access Netflix, issue is casting to them directly despite being on the same RBS device and using the same network. Same on main or guest networks.
Message 1 of 11
Guru
Re: Unable to cast via RBS750
Try turning off AX for 2.4hz
CTS set to 2347
Message 2 of 11
SKEN57
Firmware is the very latest production version for the RBR750 4.6.5.14, tried with AX off and on, CTS set to 2347.
I have several (3) satellites, all set at optimum distance from the RBR750, over 30 feet to cover 3000 sq ft. I have 1Gbs Virgin Media cable, the provided router is as standard Hub4 and set to Cable Modem mode with latest firmware. This is only since I switched from an RBR/RBS50 setup and I had the latest firmware update. Connection straight to the router works if I turn off all satellites but signal strength not best.
Message 3 of 11
Guru
 What happens if you leave all RBS OFF accept for 1 RBS?
Message 4 of 11
SKEN57
No difference at all, only difference is if I turn off all satellites
Message 5 of 11
Guru
I would make contact with NG support and let them know what your seeing with and with out the RBS enabled for Chromecast. Seems like something isn't happening with RBS enabled...Something NG should look into.
https://my.netgear.com/support/contact.aspx
Message 6 of 11
SKEN57
Logged about a week ago, still awaiting a resolution.
Message 7 of 11
Guru
Message 8 of 11
CrimpOn
Guru
Does "logged" mean:
  • The initial post on the community forum, or
  • Contacted Netgear support
Message 9 of 11
SKEN57
Logged a support request, I have ProSupport, so would like to think they are busy working on this.
@CrimpOn wrote:
Does "logged" mean:
Message 10 of 11
CrimpOn
Guru
Certainly not an incentive to pay for Pro Support.  It could have been assigned to someone who is on holiday, sick, left, or has moved on to other problems and is hoping this one has "gone away."  The "squeeky wheel" gets more attention.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1767 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
