Orbi WiFi 7 RBE973
Reply
WAN Aggregation
dstrausser83
Guide
WAN Aggregation
Hi. I got two questions...
I have Verizon Fios (1/GBS DL & UL). Will Wan Aggregation do anything for me? Should I activate it and if I do, what are the benefits and what should I do? I've only found vague info on this so far...
Second: Should I disable or enable SIP ALG? Thoughts?
Thanks!
David
Message 1 of 9
Guru
Re: WAN Aggregation
You can if your ISP modem also supports LAG.
https://en.wikipedia.org/wiki/Link_aggregation
Leave it enabled unless you have problems. Mostly SIP helps in some VoIP processing.
Message 2 of 9
dstrausser83
Guide
Re: WAN Aggregation
Thank you!
Message 3 of 9
Guru
Re: WAN Aggregation
Smiley Wink
Message 4 of 9
ekhalil
Master
Re: WAN Aggregation
Do you have 2 physical links from Verizon? Link aggregation is needed if you have multiple internet links and you want to combine them to improve the throughput.
Message 5 of 9
dstrausser83
Guide
Re: WAN Aggregation
No, I only got 1. Is it possible to get two? 🙂
Message 6 of 9
ekhalil
Master
Re: WAN Aggregation
Please check with your ISP if they can provide you with 2 links. Link aggregation is a function to use with multiple internet links to improve the throughput.
Message 7 of 9
Bandito
Luminary
Re: WAN Aggregation
I'm surprised that no one has said this, but in your situation, LAN aggregation will buy you nothing.
You have 1Gbps service and 1Gps LAN ports, so everything matches up perfectly to support your current Internet service speed.
If in the future, your ISP supports faster service, such as 2Gbps, then you would need LAN aggregation to take advantage of any speed beyond 1Gbps up to the maximum of 2.5Gbps supported by the Orbi's aggregation option.
Message 8 of 9
dstrausser83
Guide
Re: WAN Aggregation
Bandito, perfect. That is what I was trying to figure out and understand. Will it make a difference or not. That is the best answer I was looking for. THank you!
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 5367 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
