Orbi WiFi 7 RBE973
Reply
Where is the MU-MIMO setting - cannot find it.
Retired_Member
Not applicable
RBK752
Where is the Enable MU-MIMO at, I have looked at every menu for days and cannot find it yet, Netgear KB database says it’s there, I think they should update their technical support database because I cannot find the setting. I would like to enable it.
thank you
Message 1 of 4
Guru
Re: Where is the MU-MIMO setting - cannot find it.
MIMO is automatic now on Orbi AX series thus not in the UI.
Message 2 of 4
Retired_Member
Not applicable
Thank you very much for taking the time to help much appreciated!
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 931 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
